MonsterPanel - Coldfusion Datasources
Coldfusion data sources are an important part of a Coldfusion application. In this article, we will guide you through the steps of adding a Coldfusion datasource for your Coldfusion application through MonsterPanel.
Adding a data source
  1. Login to MonsterPanel.
  2. Navigate to the “Domains” tab.
  3. Select the domain you are wanting to create a Datasource for.
  4. Navigate to the “Coldfusion” section under "Domain Management".
  5. Click “Add data source”.
  6. Fill in all the following fields and then click “Create Coldfusion Data Source”.
Once you have completed these steps you will have successfully added a Coldfusion data source to the server for your Coldfusion application.
